I came to the realization that my cars speedo is off by 12kph. So when my speedo is reading 90kph my speed is actually 102 kph. How can I fix this?
Speedo reading 12kph off
Do you have larger than stock wheels? I'm used to mph but as you size up it changes I think it would read lower because yah.
C-3PO's MRT USDM yo!
195/60-R15 tires, if your not on the 14" steelies.
My guess is you have the wrong tire size on the car.
1993 SE Coupe MRT - 1992 LX Sedan MRT
93 Accord SE Bose Stereo MYTHS & FACTS - F22A* Power Plant Removal(UNDER CONSTRUCTION)
CB7 or CB9? USDM coupes/sedans have a 130 mph speedo, CB9 140 mph. From experience, my 140 mph speedo didn't work correctly when I had to replace the printed circuit board in the gage cluster (used one from a sedan). I don't remember whether it read high or low, but is was off by about the range you are experiencing. I had to install the 130 mph speedo from the sedan to get it to read close. Has the cluster been changed in your car?90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
Has it always been off? Any work on the cluster? Have you ever changed the VSS? A little more background info might help.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
