So recently my car has decided that when turning it wants to squeel or sqeak
and I lifted it up and turned the tires side to side and my upper ball joint yet again another cheap ebay part seems to be causing the noise. Its just about 15 mo old but i'm learning quick that ebay is a wast of money on vital parts
i also wanted to know if when put together properly are the lower ball joints supposed to sit a bit justified pointing more to the shock or are they supposed to be strait up and down and what is a reputable replacement for at least the upper joints? and i have a question I don't want to really start another thread but obviously when a car pulls to a side when brakeing that means your caliper isn't working properly yet i am not sure of how to check the calipers and find out if one is bad, both when full pressure was applied didn't move and when letting off each was about the same force to move neither was easy to move at any point in my test (except with brakes completely off) I did both test by hand ?
thanks
thanks
