I got a 92 accord coupe with f22a6 engine and man tranny. I want to replace all the seals in the timing belt area. I know of the camshaft seal, crankshaft seal and balance shaft seal. What are the other seals that could leak in there. Isn't there a oil pump o ring. I am having a hard time finding the crank seal on any diagram. Cam seal is easy to find oem but others are not. Any help is appreciated.
New Server Migration
Hello everyone, Pandemic here. I wanted to let everyone know that we're working on migrating to a new server which will allow for more update flexibility including SSL certifications. The old box is really old and it's been time to find a new one for a while.
Data was migrated to a the new box a few weeks ago. We're working on testing the page to ensure it actually works before we go live. If anyone has any web development or coding experience and wants to help, DM me.
Thanks!
Thanks!
What is all the seals in Timing Belt Area
Hmmm you are correct . There's other seals but I didn't think they had oil pressure behind them and thus don't leak often. Crankshaft seal, balancer shaft seal, O-irings for covers of the balancer shaft covers, crankshaft oil seal....
Originally posted by Raf99 View PostHmmm you are correct . There's other seals but I didn't think they had oil pressure behind them and thus don't leak often. Crankshaft seal, balancer shaft seal, O-irings for covers of the balancer shaft covers, crankshaft oil seal....
Originally posted by CyborgGT View PostIf by "center adjusting bolt" you're referring to the long one with a hex 'nut' at the base, then I'm pretty sure there is not a seal behind that. It should just be threaded into the engine block, with the hole not going all the way through.
Ok i finally got everything got back together and still got a leak somewhere jsut as bad. It is funny i ran it for a bit with all covers off and it didn't leak at all. My oil pressure is higher than normal when car is cold at idle and warm at idle. Normal when revved up. I suspect i have a clog of somesort somewhere. My oil pressure light is coming on and i am not low on oil. SO my oil pressure gauge reads 85psi at idle when cold. Normal is 50 when cold and 85 when revved up cold. It reads 25 when oil temp is about 180. Suppose to be around 14. I am going to change oil and filter and see whats up after. And pull off upper and lower timing cover to see where leak is coming from still. All seals has been changed and camshaft seal is only 6 years old. How would i clear or check for clog oil passages.
