EXT: A Complete USDM Black Housing DIY W/ PICS!!! (56K Be Warned!!!)
Yeah get a heatgun, its much more mistake proof than the oven. I placed mine in the oven and I just checked on them to see if they start to pull apart every few minutes. They came out fine so you could try a lower temp just to be on the safe side.
i like these headlights i would like to try this but im sure my wife would have a fit if i used her oven for that. and i think i would by a set of headlights other than the ones on my car. u think maybe a heat gun would work instead?
Leave a comment:
Yeah so I have the JDM 1 pieces, and didn't realize they're made of plastic and not glass. So when I took the headlight out of the oven, it appeared fogged up. But then I realized it's actually melted a tiny bit. Any way to fix it and make it look somewhat clear again, or am I fvcked?
edit: question moved to the appropriate section.Last edited by blakmetal.honda; 04-01-2008, 03:10 AM.
Leave a comment:
in the process of black housing my headlights, i will post pics soon
Leave a comment:
You can do it either way. I just masked off the low beam area and painted right over the black in the high beam section.
Leave a comment:
question about applying the yellow, do u have to mask the parts that was painted black in the high beam housing, or can you just paint over it?
Leave a comment:
Originally posted by benjerman112dude! i'm gonna give that a try on my extra headlight
Leave a comment:
Originally posted by djcaz_aomJust use a heat gun and lots of patience.
Leave a comment:
Originally posted by lonskiJust worried that they might be deformed, coz they're probably substandard materials.
Leave a comment:
Leave a comment:
Leave a comment:
