nice headliner 2.2, i was looking at a 1st gen Legend today. It has a similar setup that might work as well, along with rear pillar mounted map lights. If I get around to getting, them I'll see how they work out.
INT : Map light install EX and SE trim
nice write-up. I installed map-lights a while ago in my SE. I bought accessory map lights kit from my dealer for the 1996 Odyssey (ivory). You can get lofty grey too. They are the same lights as in the 96-97 Accord except the kit includes a special mounting braket that actually uses the rear view mirror mounting screws to secure the lights from above. It is a super OEM fit but takes a super-PRECISION cut for the hole. Honda supplies you with a template that works the same on the Accord. They also supply you with screws, wiring harness and wire tap. I got the kit for $59 One problem with this style of map light: my sunvisors hit the silver button when I swing them back. anyone else have that problem? BTW, it is possible to have them turn on with the dome light but you would need a diode so the whole car wouldn't light up when you turn a map light on. and yes, the dome light has two wires. one supplies a constand 12V and the other supplies 12V that turns on with the doors.
Looking to clarify the wiring. There is conflicting information here:
Originally posted by bodiby-The screws that hold up the dome light provide a constant a ground.
-Wire one goes to ground when the doors are open and is floating when they are closed.
-Wire two is 12v.
If you connect your map lights to the two wires, they should go on and off when the doors open and close.
If you connect your map lights to the 12v wire and ground, they should work independent of the doors.
And furthermore, by connecting the maplight to the two wires so that it goes on and off with the domelight, does that mean you'd no longer be able to use the maplight independently? And you'd have to leave both buttons pushed in? << that's not a maplight, it's a second domelight.
Originally posted by 2.2litrebeaterwhite/blue is 12v constant, black is ground, black/white is door trigger (provides ground when a door is open) and red/black is 12v when parking lights are turned on.
Originally posted by xaxis360BTW, it is possible to have them turn on with the dome light but you would need a diode so the whole car wouldn't light up when you turn a map light on. and yes, the dome light has two wires. one supplies a constand 12V and the other supplies 12V that turns on with the doors.>>>>>>>>>>>>>>>>>>>>>>>>>>>>>><<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
Wow, you guys blew the dust of this thread. Ive yet to mess with this and find out how I could make them work independently of the dome light but still work with it when the doors open.Just a thought here, the switch on the original dome light has three settings OFF-open door-On.I wonder if splicing a second wire on to the one 12v wire coming from the maplights and hooking it up to the constant 12v on the dome light.Thus Having three wires total hooked up to the dome light.2 12v and 1 ground EEK!! I better just stop there and try some stuff tomorrow.Ill let you know deckeda.
later
