well guys for those who want to get the most out of their intake, i also wanted to so i went ahead and did the double spacer, and found out its pretty easy upgrade.i tried to do this as easy as possible (using all onda parts)
tools needed:
1 12mm socket
2 3 cb7 compressor bolts
3 2 90' prelude compressor bolts
4 2 exhaust nuts
5 jb weld
6 sand paper
7 h22, h23, f22a6, f22b, spacer
first step: get a the spacer, remove butterflies, vaccum diaphram, rod that goes through, and fill in with JB WELD
second step: sand the JB weld till the holes are smooth
third step: take two exhaust nuts and screw them in the bolts in the lower manifold, and take both bolts out
fourth step: put the spacer first, butterfly spacer next and finish with the upper plenum, insert the prelude bolts first to align everything, and then the accord ones
fifth step: tighten everything and smile (some hoses u'll have to change, i didnt)
back view
front view
tools needed:
1 12mm socket
4 2 exhaust nuts
5 jb weld
6 sand paper
back view
front view
__
