Originally posted by Shadow1
View Post
hehehe finally at long last....
Originally posted by Clean_4th gen View PostLove it dude. Its so tempting to get one.
Originally posted by AccordWarrior View PostWhy replace the headlights? The TSX setup was for many years one of the best setups you could have.
or just replace it with a factory one for $130 for that one. idk yet.
thought about repainting the car white. was going to do white accents on the inside. thought about taking the headlight apart and painting the projector housing white and the back of it black with yellow highbeams. just small little stuff that give subtle looks.
Originally posted by Shadow1 View Postthey are indeed awesome. but one of them has the dern foggy/hazy crap on it. used 3 different headlight restore products on it and nothing. i can buy the JDM type ones for $160/pair with the clear corners
I'd just go with an OEM replacement, those aftermarket units are never as high quality as your OEM setup. I'd venture to say they'd fog over quite quick.
If you're thinking of a color change, I'd just look for a white car and start over. I'm not a big fan of color changes because you can always tell if a car has had a color change. Plus, to get a good quality respray is going to be thousands.
Originally posted by AccordWarrior View PostTry this method first as a last ditch effort.
i've tried the wet sanding one too. toothpaste. tried it all. nothing. no avail. i'll probably just replace the one headlight for the time being. the other one is perfectly fine.
as far as the repaint. it's in the air. not sure if i want to. if it did get repainted, it would be after me and the wife get the new house so i have the garage to work on. wouldn't cost me much in materials. no crazy front white pearl or nighthawk black pearl or some crap. it'll be a jet gloss black or a plain gloss white. been watching vids on doing it right to get a good finished product, so it'll be something i have to take my time on. not like my old CB that i rushed thru and looked like crap.
just my 2 cents...
Originally posted by islandhopper View PostThis method is spot on. If you follow the DIY AccordWarrior provided you, you should be able to restore your lenses. I've done this on many MANY headlights while i was working at a Honda dealership, TSX's and TL's included. In my experience there is no amount of hazing that can't be fixed with some elbow grease and patience. If you buy cheap aftermarket headlamp replacements not only are you throwing money away but you'll be downgrading to far less capable optics. The TSX low-beam projector is widely regarded as one of the best. No sense swapping them out for cheap garbage when you can spend an hour restoring your lenses for pennies on the dollar.
just my 2 cents...
and the ones i posted are NOT bad quality. i research a lot of stuff before i decide to buy something. especially something that's going to cost me $150+. tires, suspension, brakes, engine mods. all of it gets searched and reviewed for MONTHS before i buy them. like my Megan Racing lowering springs. i looked around for 3-4 months before i even got my car to decide on getting them. lol.
even if the projector does turn out to be bad quality, i do still have my factory lights and can sell them. if they turn out to be good headlights, i can sell my factory ones for $200 or keep them are spares. either way, ill end up coming out on top. haha.
Wife just bought me some Stagg struts for my CL9. $150 for the set. i know what you're thinking. they're crap. from the reviews i've seen. no. a lot of people like them. as long as you're not slammed, then they ride fine. im sure they'll go perfect with my MR springs since its only a 2in drop. but i plan to drop it another inch....we shall see how they fair...
If you "tried all that stuff before" your headlights would be crystal clear.
It's sounds like you were using one of those "restore your headlights in 5min!" kits. They never work for badly oxidized lenses. They just don't get deep enough to bring out the fresh lens.
The most important part of polycarbonate lens restoration is the wet sanding. You should be spending MOST of the restoration process here, making sure every inch is sanded properly. It takes time and patience and an eye for detail. The better the wet sanding, the better the end result. You can trust me on this; Your headlights are fixable! Just need some TLC.
Or, the easiest, quickest way to go about it is to spend the money and get entirely new assemblies. But you run the risk of getting sub-par optics from aftermarket suppliers that are designed to make money by selling mediocre parts at "good" prices, not top-quality equipment at a fair price. And trust me, if it's not OEM or an OEM supplier, the quality will be suspect.
Originally posted by drummersteve7 View Postnice dude.....hope to see you in april
Originally posted by islandhopper View PostIf you "tried all that stuff before" your headlights would be crystal clear.
Originally posted by Shadow1 View Postyou should man. OMG i love mine. every day i go out, i know it's going to start. when i drive to work, i dont have to watch for the oil light to come on because its leaking oil or having other issues. and im not working on it every day im off. only thing it gets right now is cleaned. lol.1990 Accord EX
Originally posted by Clean_4th gen View PostThats a good point. I do plan on getting one, I just have to get some things straightened out before I go for it. For now my Versa does the job, its paid off now so things are getting better.
new pics
new struts from Stagg SHS matched with Megan Racing lowering springs. ride pretty good. but the spring rates for the springs make for a soft ride. too soft for me so i'll be going to their coilover sleeves soon. they actually have the spring rates i want.
right now i have my new front lip and some different brand 6000k HID bulbs on the way. the ones i got from DDM Tuning suck. one of them keeps acting up when i go to turn on the headlights. didn't have this problem with the factory bulbs. so i can only think the bulbs are the problem.Last edited by Shadow1; 03-13-2014, 08:00 AM.
Originally posted by Shadow1 View Postas i have said, i've tried all that stuff before. i'll end up spending more on getting the drill and supplies than it would just for me to replace it with a factory one or replace both with the clear corner ones pictured above.
Generally, I only get crap headlights like this to do retrofits. But the TSX has some of the best low beam projectors on the road. So downgrading functionality for appearance doesn't make sense to me. I'm certain you can fix the lenses for less than $150.
Originally posted by gloryaccordy View PostBut the TSX has some of the best low beam projectors on the road. So downgrading functionality for appearance doesn't make sense to me. I'm certain you can fix the lenses for less than $150.
If you do end up getting the DEPO headlights, can you please post photos of the cutoff and output? I'm curious to see how they look.
EDIT: For the record, my TSX headlights have a little yellowing on them as well. I'm going to try and buff them out this month, and I'll post photos.Original-Owner 1991 Honda Accord
2005 Acura TSX 6MT
2010 Mazda Miata Grand Touring
Originally posted by gloryaccordy View Post$150 headlights are not quality. The output is going to be garbage. And odds are highthey are not sealed well and will leak. I got a set of Depo headlights for my Z and they always fog up. Not good for the bulbs. At the minimum, if you do get those headlights, swap the OEM low beam projectors over.
Originally posted by Nurega View PostI agree with gloryaccordy. For reference, the headlights on my TSX are far superior to those of my dad's bixenon-equipped 2006 750Li - a $103,000 car back in the day. The TSX headlights were far ahead of their time. I understand how much better the clear corners look (I love them too), but I'm waiting to get a used EuroR set instead.
also while the headlights out, i wet-sanded the headlight with 800, 100, 1500, and 2000 grit then sprayed a clear coat. looks fine now. no yellowing or pealing. haha.
6000K is def not better output. And just cause nobody had problems with the $150 lights doesnt mean they are worth installing. Id get em for the lenses/bezels and toss the rest.
