You know my arguments by now...
G23/g22????
If the bottom end is built, then that eliminates the issue of a low-revving, low-compression, tired stock F22 bottom end. If the bore size has been made to match the H22 head, that's even better. Honestly, it's not much different from a resleeved H22 block in that case. Of course, if it's still running stock F22 sleeves, then it won't hold up to TOO much abuse. Not like some strong Darton or GE sleeves.
However, my beef with that would be the block guard. I wouldn't trust a block guard, as they are reputed to warp cylinders.
Originally posted by WiKKeDV16 View Postitl drop u probably to 11:6:1 or so..
but.. you can go lower..
get a .078 cometic headgasekt.. and ull drop it into the 10s... boost friendly FTW..
and mike.. hush j00 mouf..lol
Originally posted by deevergoteIf the bottom end is built, then that eliminates the issue of a low-revving, low-compression, tired stock F22 bottom end. If the bore size has been made to match the H22 head, that's even better. Honestly, it's not much different from a resleeved H22 block in that case. Of course, if it's still running stock F22 sleeves, then it won't hold up to TOO much abuse. Not like some strong Darton or GE sleeves.
However, my beef with that would be the block guard. I wouldn't trust a block guard, as they are reputed to warp cylinders.'94 JDM H22A: 178whp 146wtq
Originally posted by deevergoteIf you say double dutch rudder, i'm banning you...
What most dip shits call a g23 is a h/f hybrid and it can be a torque monster and the highest n/a hp honda hydrid out there for the best price. This is what you do if your serious about it: H22A type s head, F23 Block and K20 pistons. If done right It can be done for under $1900 has a 11.5:1 compression ratio 260BHP and 200LB-FT. I have a close friend who did it and he has been running for a long time now and it has had no problems with it at all other then un-necessary wheel spin at times hahaha jk
Originally posted by PR CB7 View Postdamn...................... soooo.........
wedk's block, h head, 11.7comp, f23 HG, chrome, m2b4, one bad MOFO engine
and still be in the fsae club
We gotta do something about that C/R though.....not boost friendly at all. Gotta get it down to say at least 10.4:1 We may have to negotiate price minus the pistons....Last edited by Joey GT-R; 12-13-2010, 01:41 AM.'94 JDM H22A: 178whp 146wtq
Originally posted by wed3k View Poststop being cheap and get a custom headgasket already.New paint job and bumper 8/8/11
tsx retrofit
f22b dohc boosted
custom gauges pods
Motivation is one of the keys to life....tell me "can't" and I wll show you I can
Originally posted by deevergote View PostAnd here I thought maybe your lady was dropping some knowledge...
Originally posted by mikezzh22acb7 View PostWhat most dip shits call a g23 is a h/f hybrid and it can be a torque monster and the highest n/a hp honda hydrid out there for the best price. This is what you do if your serious about it: H22A type s head, F23 Block and K20 pistons. If done right It can be done for under $1900 has a 11.5:1 compression ratio 260BHP and 200LB-FT. I have a close friend who did it and he has been running for a long time now and it has had no problems with it at all other then un-necessary wheel spin at times hahaha jk
i mean, round BHP numbers?
no cams?
no way p5p cams will put out 200lb-ft
239-246bhp, and 189-197lb-ft would be more realistic
Originally posted by wed3kstop being cheap and get a custom headgasket already.
Originally posted by PR CB7evo pistons......................... end of subjectLast edited by Joey GT-R; 12-14-2010, 07:35 PM.'94 JDM H22A: 178whp 146wtq
Originally posted by Joey GT-R View PostI dunno....still C/R will be mad high, unless they could prove it would be below 10.4:1.
I'm not too big on Evo pistons...How many people have used them and they actually worked?750 WHP/575 TQ CD5 Raping a street near you....
realHomeMadeTurbo.com / Kaizenspeed.com / LSD Motorsports / Tempest Racing /SpeedFactory /ExplicitSpeedPerformance
GFI HOLLA!!!!!!
http://www.youtube.com/watch?v=Cdiz0k0Rudw
