i agree. I'm still thinking about running the stock cams for a bit so I can get it bar'd reffed and smogged. If i end up doing that then all I need is an ecu, new clutch, timing belt , KS timing belt tensioner and misc. Belts houses and seals. Oh and run the highest octain fuel from the pump lol
My H22 build!
http://www.cb7tuner.com/vbb/showthread.php?t=91030 <--MY RIDE!
http://www.cb7tuner.com/vbb/showthread.php?t=140230 <--MY ongoing ENGINE BUILD!..
Originally posted by youngflyndsaved View PostAny recent updates? i like your build and it's similar to one i have been planning and researching on.
Originally posted by motobmx105 View PostStil the same as above :/ I'm broke. And don't know when I'll be able to afford partsRIP '91 LX.
Well damn, now I gotta dig my H22 out of the shed and check out the condition (been mothballed for nearly 10 years and will need a thorough go through), this site has really been inspiring. Who knew there was so much love for these old CB7s! My long block is nearly stock but I like where you have gone and now I may follow suit, might as well since I'll be replacing seals and rebuilding it...1993 SE Coupe MRT - 1992 LX Sedan MRT
93 Accord SE Bose Stereo MYTHS & FACTS - F22A* Power Plant Removal(UNDER CONSTRUCTION)
Good news! The build is back on track slowly but its goin! I've got the cams in and all torqued down with new seals, now I need a timing belt and manual tensioner, clutch, ecu, injectors, fuel rail, misc. Hoses, gaskets and some little things to button her up! I'll post pics soon
Hell yea I'm still around ! I'm still rollin the ol' cb!
Good to hear! Have you looked into the KaizenSpeed timing belt tensioner? Might save you a little compared to the manual conversion.
http://www.kstuned.com/collections/k...ming-tensioner-1992 Accord EX H22 234whp 185wtq
-1993 Accord EX SOLD
-2012 GMC Canyon V8 4x4
Originally posted by GunRunner View PostGood to hear! Have you looked into the KaizenSpeed timing belt tensioner? Might save you a little compared to the manual conversion.
have you considered using the Vibrant Timing belt Tensioner...
It eliminates the slack and goes where Power Steering pump should.
We used it on our h2b crx, and anything I intend to run with power,
I will use this tensioner absolutely.
It does not take place of the tensioner, but eliminates the slack on the belt, keeping the power to the cams and crank
Originally posted by motobmx105 View Postoh yea im for sure using KS tensioner. i gotta get another new water pump cuz in transport from storage to home i broke off the mounting spot were the tensioner spring mounts on the water pump so minor set back.
You have a water pump or a tensioner? If a water pump is it new?
