1990 Accord LX Sedan with 164K miles. I have a little leak and wonder if I should replace the seals or the whole pump. I don't have an impact and removing the pulley could be a problem. The leak seem to be at the seam of the pump rather than the thicker pulley o-ring. It's also leaking by the plate right below high pressure hose. Please see pic.
My question is to replace the pump, is there a lot of fluid leaking out of the pump after the car is cool and sitting over night? How much fluid should I top off after?
Thanks.
Thanks.
There isnt really a need to ever buy a new or used pump because they are really easy to rebuild and cheap. Plus like I said the only thing to go bad is the seals.
