First of all im in a rush typing this....
I'm doing my first motor swap and its all back together and turning over when I try to start it but my check engine light isn't lighting up when turned to ACC, but everything worked fine when the last motor blew.
Usually it comes on until the fuel pump kicks off or primed.
I can't hear the fuel pump kick on, I disconnected the fuel like to the manifold and nothing, then I found out I'm not getting spark either, I'm pretty sure every ground is good even for ecu, I tried 2 ecu's and 2 main relays. Nothing.
Will update later... Sorry gotta go to work.
Any help will be appreciated.
