What did you use to clean your bay? I notice a brush lol nice job in the tuck btw. I still have to do my passenger side. Hopefully I won't find any cut wires like I did on driver side
Lol I used a broom stick for a hood prop. Good luck on the wire tuck, by the way I hated redoing that part.
I went back and checked out the turbo and manifold. You are going to run a half size triple core rad, right?
Goodness Gracious! I hope you have some meats planned for the fronts on track day! I want you to join the CB7 11sec. club. Only Boost and NW are there, maybe Scott too after he went turbo.
*** Think of others before thinking of yourself. ***
lol , yeah man. I am aiming for 10's. Triple core radiator is a must. I think NW has gone the fastest.
That would be pretty crazy to see a record breaking CB this summer!
I am going to try as hard as I can without blowing up the tranny. So far everything else I have should be enough for a 10 sec pass. Still debating on slick size for the track. I plan on making it a true street car that you can drive to the track , make a 10 sec pass and drive back home.
Since you mentioned that idea, have you thought about getting the QTP exhaust cut-off? I am planning on running this, so when I want to be a little stealthy I can close the open dump and run the exhaust through the full 3" exhaust system. Then when I hit the track you open up the straight dump pipe for the extra ponies. http://www.quicktimeperformance.com/QTEC/index.php
I thought about that , but I think I am going to run just a down pipe.
