Made intake piping bracket to hold up filter-end of intake system, it's solid and based of a tranny mount stud to move with the motor and not frame. Painted it black, blends in like stock, even made a semi-circle cutout for lower radiator hose clearance.
Anyhow, some minor bodywork I want done is next, then fuel tank installation and creation of 3" exhaust.
However, I found today being under the car that Prothane can lick my balls. Them rear lower control arm bushing sleeves are moving independent of the lower arm bore itself, so I can knock with mallet the arms back and forth. Some press-fit that is. I hate doing things twice and it has ALWAYS been because of aftermarket quality/fit & finish issues!! It's pissing me off, seriously! So to solve it, I'm removing them d**n lower arms again, removing the poly bushings (keeping metal sleeve in lower arm bores) and tack welding the metal sleeve to lower arm, then reinstall everything. This crap is depressing to me.
So things are tight, but on track to be done before Monday 10 am when I have my initial dyno appointment. I'll be working on this up to Friday, not Saturday and if I have to Sunday. Monday, hopefully just loading the car onto a trailer or if we have time, before.
__
Have a good break-in
