take your car to another tuner and do what i said. You also need to have the tuner TUNE the individual cylinder as best as possible. You will never get everything out of your engine just throwing a single timing number at each cylinder. Each cylinder is going to want something different than the other, and although doing this takes a lot of time with pulling the plugs and reading them, it makes up for itself in the end. I'm running 33* actual timing in my engine at peak torque. Some people call that crazy, I call it a thought process.
Cisco NA F22 non-VTEC SOHC Project - Full Street White
Originally posted by HondaFan81Sent you email. Hmm, now that I think about it, I think you are thinking at a more simplistic level then I described in my email. You're saying to tune and read plugs per cylinder that will result in a better overall tune.
read the bottom link in my wiki.
I'm not sure about ignition. I know it's possible with eCtune. Hell, even Crome has the fuel trim options. Not sure how well it works though, lol.
But yes, a knowledgeable tuner will know how to read spark plugs and tune the timing in a correct fashion.
*edit* I don't see individual cylinder ignition trim, but I do see individual cylinder fuel trim.Last edited by d112crzy; 06-26-2009, 06:53 PM.
Originally posted by d112crzy View PostI'm not sure about ignition. I know it's possible with eCtune. Hell, even Crome has the fuel trim options. Not sure how well it works though, lol.
*edit* I don't see individual cylinder ignition trim, but I do see individual cylinder fuel trim.Last edited by HondaFan81; 06-29-2009, 08:43 AM.
everything seems to complicate itself in this thread/build... i say get some mula together, get the immigrant (d112) over for a decent tune, and run the hell out of it already! too many minute details are being given wAy too much attention...
i've been SOO anxious to see this "beast" hit full potential and seems like progression is scarce...
absolutely NoO hard feelings intended...
good luck!
THEN: 1993 Accord 10th Ann. Ed.---------------------- NOW: 1996 Accord EX
My Ride thread
Flickr
Originally posted by d112crzyAnd it can only get better. That's the best part.
All I gotta really say is:
People of cb7tuner, this AUTO is NOT a joke. It has impressed ME, the hater of auto's.
Originally posted by dbsharpdid you make the appointment for aug 10? Thats not long to wait considering how long this project has been going on.
I have all the parts for upgraded crankcase ventilation, having the male -AN fittings welded to the valve cover today, need to mount the catch can and install -AN fittings onto the SS braided hoses. I'll need to clean the piss out of that valve cover, making sure no contaminants behind the baffling. I'm thinking of mounting the catch can in the firewall area where the fuel vapor canister is, but I have to look into how to remove that canister properly and still retain fuel tank vent functionality.
I removed the plenum last night and completed the modification at work today.
Also, this weekend I have to do some maintenance work on my parent's 01 Odyssey and 88 Integra. I haven't had time for myself lately. Last couple weekends I have done maintenance work on my bro's 90 Accord EX and sister's 91 Accord EX.Last edited by HondaFan81; 08-07-2009, 02:04 PM.
In exchange for work on maintaining my parent's and sibling's cars, my dad just bought me a brand new OEM F22ax stock crank pulley! I've been wanting one as preventative maintenance due to rubber dampener deterioration and the higher RPMs this engine will experience.
EDIT: Received.Last edited by HondaFan81; 08-18-2009, 03:05 PM.
Last night, I completed the intake manifold modification, all is reinstalled. Also, I completed the fuel charcoal canister delete and utilized this location for the new breather catch can setup that I installed as well, looks clean. However, last minute I noticed the 90 degree elbow fittings don't allow the hood to close. This prevents streetability, but for dyno purposes is fine. Going to have to look for lower profile elbow fittings. Anyhow, ready to go for another dyno session.Last edited by HondaFan81; 08-11-2009, 01:24 PM.
Let's play a game called good news, bad news.
Good News:
New tuner, same dyno type (Mustang), slightly larger HP numbers at 192 WHP/135 WTQ. The HP & TQ curve look smoother.
Bad News:
Idle inconsistency and braking/brake booster problems all due to low/no vacuum at idle/lower RPMs.
My Thoughts:
I am disappointed that the driveability issues are not fixed, as I want to drive this car on the street. However, this dyno session only shows there is still more potential in this build, which excites me.Last edited by HondaFan81; 08-15-2011, 12:35 PM.
