DrummerSteve7 : H23 Boost Build
    unplug the map sensor and it runs like shit......
    but no idle issue.
    so gunna try swappin out map sensors.
    MadLab Racing
    Southern Maryland
      Good to hear it's up and running for you man? She'll be purring like a kitten brfoe you know it!
      CB7Tuner Resident Gamer!
      PSN: JDMcb7TX
        just gotta figure out this map sensor thingie.
        MadLab Racing
        Southern Maryland
          Originally posted by drummersteve7 View Post
          got the plenum together.
          no leaks no nothing.
          but I can not get it to turn over now.
          I get spark, I get fuel.
          I added grounds. and I know the battery connection is good any other ideas?
          FUCK!
          Battery ground to the tranny (IF ITS NOT TUNING OVER AT ALL)... Also ground that goes to the rear of the manifold is key.
          750 WHP/575 TQ CD5 Raping a street near you....
          realHomeMadeTurbo.com / Kaizenspeed.com / LSD Motorsports / Tempest Racing /SpeedFactory /ExplicitSpeedPerformance
          GFI HOLLA!!!!!!
          http://www.youtube.com/watch?v=Cdiz0k0Rudw
            it is running man. I guess just the one spot I had it hooked into it doesnt like me. so yah!
            everything is good now. running real rich.
            h23 with 450's! ya know!
            thinkin about throwing the turbo on because I do not wanna drive it as loud as it is.
            I will just stay out of boost.
            as far as CEL code 6. the engine is not getting hot enough for me to determine which sensor it is.
            waiting for the temps to rise so I can see if the ffan comes on.
            MadLab Racing
            Southern Maryland
              well the snail is back in.
              all that is left:
              turbo feed line
              intercooler piping
              I got 2 hours tell the lady comes home, so looking good on that aspect.
              hells yah!
              should be good. then it is time to save money and get her tuned.
              MadLab Racing
              Southern Maryland
                good work stevo!
                WHITEONWHITE
                  small oil leak coming from the banjo bolt on top of the turbo.
                  figure that out later.
                  otherwise she is running and standingby for tuning from tempest racing.
                  hopefully the middle of the month.
                  we shall see!
                  MadLab Racing
                  Southern Maryland
                    Awesome work bro!!! Can you just use tephlon tape to mend the fitting bro?
                    PSN: JDMcb7TX
                      most likely. I went around the block and manifold is hot.
                      So I am going to wait.
                      might have just come loose, who knows.
                      worst case, a new banjo bolt is a couple of bucks.
                      I need to order an exhaust gasket for the o2 housing anyways.
                      so like 30 bucks in parts!
                      but all is going real well right now.
                      MadLab Racing
                      Southern Maryland
                        Sweet... Just a tune and then you are set after getting all these small things taken care of then.
                        Awesome work man can't say it enough!
                        PSN: JDMcb7TX
                          hey steve u can get banjo bolts from car quest in hollywood,md thats were i got mine
                          WHITEONWHITE
                            cool man.
                            I am not sure if I can get tuned middle of month.
                            money might be holding me back.
                            maybe I can sell some stuff, who knows!
                            If I can get rid of these civic wheels, then sweet!
                            MadLab Racing
                            Southern Maryland
                              Front Torque Mount?
                              Hey, I had a question. That front torque mount you have installed, are you taking it off once you go boost? The reason I ask is because it looks like it uses a 2 point mount bracket, and one of the points goes to the bolt hole you have to cut off the block to get the Mitsubishi turbocharger to fit in.
                              I was thinking about getting the front torque mount, but talking to them as seeing if they would engineer me a mount to use the two vertical bolt holes instead of the two at the top.
                              Just curious.
                              Been a long time. Still alive...
                                Just curious.
                                it had to be removed for the dsm setup.
                                down the road I plan on doing a better setup leaving room for this mount.
                                if you are using the internal wastegate, even the vertical holes are blocked.
                                I will get a better pic for you when I go home today, weather permitting.
                                MadLab Racing
                                Southern Maryland
