CyborgGT : 1993 Accord EX wagon
    The cat was indeed installed Thursday, and then he spent some time that evening working on the tune at idle. Over text, he was pretty complimentary about the car and the engine, saying it sounded really good. He upped the duty cycle on the IACV and says it's idling really nice now. Just a bit lopey because of the cams, but who doesn't enjoy some cam lope? At this point, he's just waiting on some open dyno time at one of a few shops in the area.
    In the meantime, here's an updated exterior shot from when we were loading the car onto a trailer...
    It's come a long way.
    Accord Aero-R
      damn looking good
      Omar | aww_shiet | Facebook | Instagram
        Dude that look awesome! I like the little ducts, I can't remember, but those are fuctional correct?
        ~Nick~
          Yes, they're functional... at least in theory, haha. There's a hose coming off my enclosed intake filter that routes to that now empty space behind the bumper. I'm hoping that with this design, I'm getting the benefits of a real "cold air intake" without the risk of hydrolock.
          Yesterday was dyno day... and it was quite anticlimactic. I learned a lot.
          - Living at elevation (me at 5,000+ ft) SUUUUUUUCKSS. Researching almost identical builds to mine online, even in our own all-motor records list, I was expecting to make more power. I ended up making 202 at the wheels. Sadly, this went down at PFI, who for some reason don't seem interested in hooking up their dyno to read torque. I was told I might gain 20hp with E85, but I'm not interested - I imagine it won't be available in a mainstream way for much longer anyway. I think VTEC was set at around 6500 to smooth out the transition, even though it's still a loud crossover. Fuel cut looked to be right at 8k, if my tach is accurate. Power starts to drop off a bit after 7k.
          - That said, a small turbo is definitely in this car's distant future, if it's possible to clear factory accessories. I'm definitely not ditching p/s or a/c for that. Before then, though, I do want to experiment with more all-motor mods to see if I gain anything significant. At least a better header (HyTech, if possible) and K-series intake manifold (S2 Ultra Street). I'll probably upgrade to FuelTech eventually as well. Part of me is taking this whole experience as a challenge, haha.
          - Maybe it's because I've only ran the car in shop-like atmospheres and the storage center, where poor acoustics is a thing, but the exhaust is overly loud and really boomy down low. My 3" back section will be reduced to 2.5" to match the rest of the system ahead of the gas tank in an effort to try to quiet it a bit. I'll do that when I get the coilovers that I need to tuck the back of the exhaust up higher anyway.
          - Evidently I've got electromagnetic interference going on, because the tuner was having trouble connecting his laptop to the ECU. He says it shouldn't affect drivability, though. I'm thinking it might be because of all the gauges I have in the glovebox and the proximity of their wiring to the ECU's USB cable, but I'll have to figure that out.
          I did get a video of one of the final pulls, I'll post that soon. And I should be getting the car to an emissions center in the next few days; Colorado's inspections are still pretty lax, but that'll be an interesting experience.
          Accord Aero-R
            Well.... it's a good base. We can say that for sure. A small turbo to take it to 300HP would work while keeping the 2 5" exhaust.
              This is a milestone at least. It seems like other than the atmospheric effect the car was running soundly. I can’t wait to see the video from the dyno. Hopefully after your emissions appointment you’ll be able to take it for a bit of a drive.
                The audio. Sounded slightly deeper in person...
                Accord Aero-R
                  Sounds great! It's a fun acceleration too, especially for the wagon! Long ago I only had the F22...and I remember going for a drive in my friend's prelude. All I could think was " ahh..it keeps pulling into the high rpms. " was always so fun.
                    This sounds really good. I also really like your exhaust tips.
                      Damn that was great sounding.
                      Super healthy tune at that too, I saw zero smoke of any kind whatsoever.
                      My tunes were always too rich as WOT would cause black smoke.
                      But this is all before a wideband.
                      MRT
                        And yet another potentially long delay before this car's in the clear, after failing emissions pretty spectacularly.
                        This was right after the tune:
                        The tech there suggested the CO number was a "massive vacuum leak." I took the car home and looked it over, found that the brake booster hose was dried out on the inside, so I replaced that. I also tightened down the nuts on the thermal intake manifold gasket a bit more. Went back in and while there was a significant improvement, it's still way the hell off the charts.
                        The car was noticeably better to drive though, so the vacuum leak explains why the tuner had trouble getting it to idle. I feel kinda confident that it's not my lack of EGR, or NOx wouldn't be so far under the allowed limits. Researching that a bit, it sounds like EGR attacks NOx at the expense of increased CO and HC emissions anyway (why it's even such a hot-button issue with the EPA these days is confusing the hell out of me). I feel like with how close the HCs are, it's probably the tune running rich just to get it to idle; the tuner feels the same - and he did say he wouldn't charge me for a re-tune while I figure this out. I did delete the EVAP canister, and at this point I can't remember if my reasoning was related to the 'black box' that I deleted because I now have a throttle body-mounted MAP sensor and no EGR. Is the charcoal canister even plugged into that box? From what I'm reading, a malfunctioning (i.e. missing) EVAP could contribute to "excessive" CO emissions and a rich running condition.
                        I'm really, really hoping it's not my cams, knowing that cams can have a big impact on engine vacuum. I'll try to hook the EVAP canister back up and get the tune double-checked, but can the EVAP have that much of an impact on CO?.
                        Thoughts?
                        Oh, and my cam seals might have just needed to 'break in,' because after the dyno session and these two hour-long drives for emissions, it hasn't leaked a drop. Still have two new OEM seals on stand-by...
                        Accord Aero-R
                          wow..... wish i could help. (and glad I don't have to go through this). All these measurements are coming out the tailpipe?
                            Yup
                            Accord Aero-R
                              Well, congrats on finally getting it tuned even if it is not perfect.
                              Isn't EVAP system for the unburned fuel / vapors recirculating back into the manifold? I know some engines the EVAP or EGR system is a hole cast in the intake manifold, to which us gearheads machine a block off plate and remove the entire system.
                              Is that the same as what you have done?
                              You may gain power with Ethanol but I'm pretty sure your won't gain gas mileage as it takes 15% more fuel to achieve the same result, or something like that, at least with turbo applications, something to keep in mind.
                              There are various levels of Ethanol too, like petro gas has 87, 89, 91, 93, respectively (kind of lol). So you may find E70 or E85 or E whatever depending on the time of year and station. Some aftermarket performance companies sell a Ethanol test kit, it's a test tube with some other stuff I forgot about cause it's been so long since I have run that stuff, but you can test to see exactly your Ethanol rating for better tuning.
                              Nice job on the wagon so far.
                                Yeah, EGR is blocked off with a plate. I don't think EVAP will really do anything for tailpipe emissions, it's more evaporative, but the responsible adult in me kinda wants it on there anyway. And I'm not interested in ethanol because of the inconsistencies, spotty availability around the country, and fuel economy.
                                I'm really hating the internet right now, lol. Trying to research my issue is depressing and making me second-guess my work leading up to this point. Like if I degreed the cams properly (and the damage that could have caused), and if it's even possible to pass emissions on these cams. My stock cams are chipped, they can't go back in. It's making me want to pull the engine to double-check everything, which could easily turn into an expensive venture if changes need to be made. Not to mention stretch this project well into yet another year. But for now I've got a couple small parts coming and I'll keep tinkering and doing what I can at home without pulling the engine, then go back in for a re-tune and see what comes of it. Hopefully it's just down to the rich tune he needed to get it idling on a vacuum leak. No idea what that timeline looks like though. If it still fails, I don't know what I'll do at that point. Ditching the headaches for a later time and getting a stock H22 just so I can finally drive my wagon is awfully tempting right now.
                                Accord Aero-R
