Originally posted by CyborgGT
View Post
CyborgGT : 1993 Accord EX wagon
Originally posted by CyborgGT View PostNext up was the Prelude shifter. Looking through the DIYs, it seems like everyone just forces the bolts into the bushings and tightens it down in that stressed position. I didn't like that, so I elongated the front holes so it all sits more relaxed before bolting down.
Shifter and pedals in!
I installed the ITR shift boot onto the console, and couldn't help mocking it up with the Circuit Hero extender and Skunk2 knob. That knob is so heavy for something so small, it's awkward to hold and I actually dropped it on the ground, so now it's got some little gouges in it. I'm feeling stupid for that...
Leave a comment:
Originally posted by Raf99 View PostIt is a pain, especially with a H22! Looks good though, cost a lot for all that fluid and parts but sooo worth it as it's a wagon!! Sweet!
I got a basic Duralast clutch for the initial install and test, though (yay for holiday overtime at work), so unless I'm forgetting something I should be good to put the new transmission in this weekend. I found this stainless clutch line to replace the rubber one on top of the transmission as well, made by Phase 2 Motortrend. Unlike the Valex line to the master cylinder, this one has a clear rubber sleeve to protect against fraying (*ED. - correction: the Valex line does have a protective sleeve, it's just not as thick). I'd never heard of the brand before, but it feels like a quality piece.
Leave a comment:
Leave a comment:
And the slushbox is out. What a pain in the back... upper and lower.
Can. Not. Wait. Until my sparkly-clean engine and trans are in. The wagon's definitely getting a trip to the car wash once the F22's out. The entire engine bay is this disgusting.
Came home afterwards to the rest of the parts I need from Honda, delivered a day early! Enough fluid for three quick changes, to really flush out whatever was in there before; pads for the clutch and brake pedals; clutch release fork boot; a couple drain plug washers; the output seals for the axles; and the reverse sensor that was missing.
Leave a comment:
I hope so too! I've never owned a manual car (the sedan and RSX being the only other cars I've owned), so I'm not as familiar with them and am doubly nervous, haha. I need to keep an eye on my budget, but I could have this running within the next two weekends. I just remembered I still want to get a stock-spec clutch for testing purposes, so I'm not wearing out the Exedy before the H22 goes in. I have a friend who's owned several manual cars, so he'll be making sure it feels as it should.
Leave a comment:
This is exciting. I have never done this, but I hope that it goes smoothly.
Leave a comment:
ARP flywheel bolts work, thankfully. Found some pressure plate bolts on eBay as well, which just arrived today. As I refresh this transmission and figure out what I still need, a cart at Majestic is building up...
Cleaned up the transmission as best I could. I have a bolt plugging the hole for the missing reverse sensor, but I'd rather get that new than from the junkyard, so that's in the Majestic cart. I did find a proper breather tube cap at the 'yard, though!
Installed the Speedfactory detent springs:
As well as the MTEC shift springs:
And the new slave:
Leave a comment:
That is pretty irritating, but I’m sure I’ve done something like that before. Not knowing if someone left it to come back to or not.
Leave a comment:
Another story of "just my luck." So yesterday, when my injury cut my junkyard trip short, I was in the middle of grabbing the clutch pressure plate bolts. I didn't have a 12-point 10mm socket on me, so I was using the too-thick box end of a combo wrench. It wasn't quite fitting in the tight space, so each bolt was taking time and effort to break loose. Which is when my hand slipped. In my pain, I didn't think to throw the four bolts I had already freed into my tool box, and left. I went back today with the right socket, and the four bolts were still laying right where I left them, in plain sight on the pristine trunk carpet I laid out right next to the engine block. But someone took the two that were still on the clutch! They didn't take the pressure plate or clutch disc, just the two bolts. In fact, the clutch kit was still attached to the engine, via the dowel. I can't remember having felt so cheated before. It's not that big a deal, I can get those two remaining bolts online... but why?
Leave a comment:
Hoping to solve my too-short automatic flex plate bolt issue with an upgrade (I heard it's not good to reuse old bolts for this application?), we'll see if they fit. Part number officially lists them only for B- and D-series, but searching for "ARP H22 flywheel bolts" still brings these up...
Another story of "just my luck." So yesterday, when my injury cut my junkyard trip short, I was in the middle of grabbing the clutch pressure plate bolts. I didn't have a 12-point 10mm socket on me, so I was using the too-thick box end of a combo wrench. It wasn't quite fitting in the tight space, so each bolt was taking time and effort to break loose. Which is when my hand slipped. In my pain, I didn't think to throw the four bolts I had already freed into my tool box, and left. I went back today with the right socket, and the four bolts were still laying right where I left them, in plain sight on the pristine trunk carpet I laid out right next to the engine block. But someone took the two that were still on the clutch! They didn't take the pressure plate or clutch disc, just the two bolts. In fact, the clutch kit was still attached to the engine, via the dowel. I can't remember having felt so cheated before. It's not that big a deal, I can get those two remaining bolts online... but why?Last edited by CyborgGT; 11-17-2020, 02:00 AM.
Leave a comment:
Leave a comment:
