Originally posted by Raf99
View Post
Raf99 : 1993 Accord EX
You're using one of those caliper adapter blocks to run those calipers, right? Can that be safely milled a hair to bring the caliper in toward the hub, or is there not enough clearance between the caliper and rotor to allow for that? Also taking into consideration where the pads contact the rotor, etc.
As for the receipts, I'm going to guess along the same lines as these guys. Mine, not including the $1500 the car itself cost, is just over $28k so far. And I know my running list is missing a couple things, such as the customized JDM headlights. You have that complex turbo setup which costs a fortune, but I've spent money on different details and I've documented everything I've spent... so probably roughly the same.Last edited by CyborgGT; 04-25-2024, 04:11 AM.
CyborgGT, cannot move the bracket as the caliper is mm away from the rotor inside of it. I really need a wider wheel or one that doesn't have the "lip" where the wheel weight goes. OR I shave the heck out of these calipers, I will say there is a lot of material there but this may be part of the cooling material; not sure. I do like my current wheels though.
...... the magic total was $41,789CDN ($30,607USD). You were all close. That's a H22, + another bottom end H22 + $10K+ of turbo parts and dyno sessions. Full exhaust setups. Most of the stuff had to be ordered from the US as I'm up north where the reindeer fly. Carpet, lights, more lights, fogs, intersection lights, harnesses, clusters, traction bars, calipers, S300, Skunk2 intake plenums, stereo equipment. Dam, I remember buying my rear disc setup from DarkCloud back in the day as I couldn't find it in Canada. Local bought items like wheels, seats, and engine blocks, heads.....
Hmmmm.
Finding issues = good.
Interesting pic. The traction bar goes on top of the oil catch can hoses (not shown here). Those hoses go on top of the intercooler piping. That piping is on top of the radiator hose. That hose on top of the head heater/coolant hose, that hose on top of the shifter cables.
Debating on painting this green...
Yep. Giving up on the big brake upgrade for now. These wheels will not work here. I'd have to shave about 1/8" or more off the caliper, then more to clear the wheel weights.
And.... I'm hoping to move soon. It took me a year but I found the house I want (has everything I want) and my house is on the market now. Fingers crossed!
If I do move you'll see the photos on my MRT stop working for a week or so as they are hosted off my server @ home.
Thanks all. Found the house I want, need to sell my house to make it happen. This is the first week for the house on the market!
Meanwhile, I'd say this is the most nervous start of my life.
https://youtu.be/z2T7DaRZ3xk
Sounds decent for a first startup. Things will slowly quite down a bit as it gets some run time on the motor.
I started assembling the motor for the Pilot last night. Got the main bearings all measured out. Got the rings sorted out and measured. I need to get the pistons on the rods, rings on the pistons and into the block tonight. But yea if this was your first time doing any of this work it's a bit nerve racking on that first fire up. I remember starting up the H22 after I rebuilt it. Primed the oil a bunch and then tried to start it 5-6 times and it wouldn't even fire a bit. Went to bed at like 1am so defeated. Went to work the next day, came home and she fired up on the first crank. But I was so worried and nervous all day long.
It can only get better from here.Last edited by Rilas; 05-09-2024, 12:24 PM.
- 1 like
Oh ya first starts are the scariest. Sounds really good actually! Nice work dude!~Nick~
Soooo got some guages hooked up and there's obviously an increase in oil pressure. But that is expected with the balance shaft delete kit.
New
Ignore the A/F as there's no intercooler on it. I definitely notice the vibration in the cab of the car but to touch the engine it's fine at idle. The car is also on jack stands. But I can tell the engine sounds smoother and cleaner. "Newer".
Soo.... next...
- Get SManager working, connect intercooler and piping / complete the loop. This should fix the A/F
- See if the car works. I know the stupid transmission is leaking a drop every night.... grrr.. dam silly idea to have a seam where the fluid collects at the bottom.
- Will check the plugs out.
- The knuckles / bearings / hubs all went to a shop to put together. Putting new LBJ in too
- Brakes need to be bled
- No idea where my power steering fluid went but the reservoir is empty & I can't find the PS pump adjuster bolt anyways...
- Need to get this car mobile!
And also packing the whole house and garage in hopes that someone buys this and then I'll be moving. For Sale sign is on the lawn! If successful we upgrading from a single garage to a double
