I'm already well into reassembly for that. I've got the whole driver frame rail back together, and just about all of the firewall. Fluid leaks from here on out will be kept on top of, so buildup shouldn't be a problem. Good to know that about carnauba, though.
Also forgot that I still need to take my Accord/Prelude power steering lines to a shop for splicing together, which I probably won't have the time for until Monday...
CyborgGT : 1993 Accord EX wagon
Originally posted by CyborgGT View PostNope. Decided I'd spent enough time in there, and it looks good enough.
Leave a comment:
- 1 like
Leave a comment:
This looks factory clean!!! Your hard work was definitely worth it.
- 1 like
Leave a comment:
Originally posted by CyborgGT View PostHaha, thanks man. I've been meaning to get a steam cleaner forever, they can be used for so much. I'm feeling kinda cheap about it lately, though.So then you can work on the fun stuff.
Leave a comment:
Ahh that area. You're almost done in there :P Ya, I've spent a couple hours there. When I did the first engine pull it was 15+ years of gunk in there too. Ya, good point on the steam cleaner. I recently bought a power washer off Amazon and the downside of using it is that shit gets everywhere! You may push dirt and grease into areas you don't want, or make a complete mess vs. steam. Too bad you can't borrow someone's electric power washer. What's next?? Nice to see a good H22 build / install
Leave a comment:
Leave a comment:
Finally! I can post!
First of all, lovely lovely work you're doing! And for the grime, back in the day a lot of people where using some degreaser and then a steam cleaner to get off grime like you're dealing with. It might even save you a trip to the car wash completely. My wife has one that she uses to clean the grease off of the kitchen stove and hood and she says it works 10x better than just straight cleaner--might be worth a shot since it will save you a lot of time!
Leave a comment:
Originally posted by Raf99 View PostPS Pump looks close to what i'm using on my H22, the 5th gen accord / 1995 accord PS.
I am jealous of the simplicity and emptiness of your bay right now, though. I don't think my pictures are giving justice to how bad I've got it in some areas. It's not as simple as soaking it in degreaser and wiping it away, this grime is requiring a plastic scraper and some serious brush scrubbing to get off. In this area here (wish I had gotten a 'before' photo), I went through my process of plastic scraper to get the majority out of the way, soaking what's left in degreaser, scrubbing it with brushes, and going through several paper towels wiping away the liquefied mess, only to find some stubborn stuck-on gunk was left behind and I had to repeat the process all over again. I'd feel guilty if I had gone straight to the car wash and put this soup of engine fluids and road dirt down their drain, but after I get it "clean" by hand, it'll still badly need a soapy pressure wash to get all the tight spaces in between things I can't get to, and clear up the splatter created from cleaning new areas. It'll save time and materials.
Leave a comment:
The pressure washing is more just to get into the tight spaces that my fingers can't or are otherwise annoying to clean. Just being meticulous, is all.
Thread checker's to measure bolt threads, so I know exactly what to order to replace them. None of the bolts actually need replacing, but... well, then they'd all be sparkly-clean and have matching heads. Even just looking at those OEM short 10mm bolts throughout the bay, I found at least three styles of head, with and without washers. It was annoying me, haha. Again, it's just me eyeing the details. It's my curse for growing up going to car shows, even though I'm not really building a show car.
Leave a comment:
Ya at first i was like "pressure wash?, I'd do that by hand...", then i kept scrolling. I'd still do all that by hand. Some wipes and mild degreaser, but ya some of that looks caked on the drivers side pretty good.
What is the thread checker for?
Leave a comment:
Leave a comment:
