I think we'll know tonight!
Cisco NA F22 non-VTEC SOHC Project - Full Street White
GL with it and cant wait to see the dyno graph of this thing.
The New-ish Ride
My old Ride
Hear my Vtak!!!
MK3 Member #3
I piss off people for fun.
IA 08 Sunburn Victim #1
I am more interested to see where it makes the torque which should be pretty impressive.
The New-ish Ride
My old Ride
Hear my Vtak!!!
MK3 Member #3
INTRODUCTION TO FIRST DYNO SESSION:
So the copper BCPR7ES-11 NGK plugs used to break-in the motor fouled out and were replaced with BCPR7EIX-11 iridium versions. Then, the tuner noticed the brand new Kteller Acura/Honda TPS was not reading correctly with numbers all over and inconsistent. Luckily, he had a spare OEM he installed on my car that worked well. Keep in mind this tune is TPS based maps. After that was all squared away, on with the rest of the tuning. This tuning session was on 93 octane pump gas and the injectors have been upgraded to RC 550 cc/min peak & hold since the break-in tuning.
To remind all, this motor has a very aggressive Bisimoto F22 camshaft in it, along with about 12.4:1 compression. This motor was set to idle at 1300 RPMs. The tuner set idle the best he could. However, it would still stall out occasionally. Then, the tuner proceeded to tune for WOT. He did some runs in the 6000 RPM range, eventually to 7000 RPM and then 7500 RPM. The information for the 7000 RPM pull is listed below. The tuner noticed the air/fuel ratio curve for this motor had peaks and valleys that were in correlation with the HP and TQ curve at 5000+ RPMs. He found this odd and never seen it before. Based on this information and myself being weary of going beyond 7500 RPM, I did not want to pursue the dyno session, since time is money.
EDIT 6/23/09: Initially, management was MAP based and later converted to TPS. The peaks/valleys were found to be a conversion mistake, resulting in low ignition timing values.
AFTER FIRST DYNO SESSION:
Later, on my return home the new plugs installed for the dyno session fouled out again. The motor stumbles below 3000 RPM due to running rich AFR and fouls out the plugs. I was content with the "monitoring specs" of the motor, it made me feel more confident in the motor. After speaking with Bisi, its seems my dyno tuning and idling issue may be due to me not degreeing the camshaft. I simply set the timing belt like stock, which may not be a good enough starting point with this aggressive camshaft.
EDIT 4/09: Camshaft is degreed, only a 0.5 degree retard adjustment was made, not the cause for the issues.
MONITORING SPECS ON THE MOTOR:
- Oil temp maxes at 220 deg F, after a good drive.
- Oil pressure maxes at 105 psi, warm idle between 65-75 psi, maxing out at 105 by 3500-4000 RPM.
- Engine coolant temp maxes at 195 deg F (thinking about lower temp fan switch).
- No leaks of any kind, starts up quick and strong.
MUSTANG ROLLER DYNAMOMETER:
** NOTE: Tuner made mistake converting MAP to TPS based maps, resulting in low ignition timing values.**
186 WHP @ 7000 RPM
147 WTQ @ 6100 RPM
TORQUE SWEEP:
3000 RPM - 110 WTQ
3900 RPM - 117 WTQ
4620 RPM - 132 WTQ
4800 thru 5100 RPM - 139 WTQ
5480 RPM - 128 WTQ (dips down)
6100 RPM - 147 WTQ (comes back up)
6500 RPM - 128 WTQ (dips down again)
7000 RPM - 140 WTQ (comes back up)
TO BE CONTINUED....Last edited by HondaFan81; 08-15-2011, 12:33 PM.
Originally posted by Grumpys93still good numbers you rose the 109whp to 180whp thats a significant gain and on top of that you have a fresh motor what else could you ask for. I bet that if you ran this against a h22 swaped cb you would walk them. But good idea on not reving past what you feel comfortable.
I have idled 1000's as well as 1600's on hondata no problem as well as gotten it to maintain a 900rpm idle.
member ride thread
DIVULGE MOTORSPORTS
John 10:18 "No one takes it from me, but I lay it down of my own accord. I have authority to lay it down and authority to take it up again. "
Well, just got off the phone with Bisimoto Engineering, got some great tips and apparently their support to help me out on my issues. What great customer service!!
A major point was I never degreed my camshaft and it is critical in this setup. I have never done this before, but have instructions on how, not much to it. I simply had my camshaft set at 0 degrees/stock setup and was planning to do cam tuning to dial it in. I do believe that my camshaft is not in sync with my bottom-end, based on previous tinkering and the strange A/F ratio curve. This would obviously mean I'm losing power/compression dynamically.
As I said before, I just have to dial in this motor. I am already impressed on an improper setup it has made the values it did. This motor has potential!!Last edited by HondaFan81; 12-09-2008, 02:17 PM.
Originally posted by d112crzySo much detail, yet you skimmed on one of the most important parts of a build. You might be able to rent a degreeing kit from bisi. They usually go for about 300.
Also, updated previous post on my first dyno session to clear up some items. I have not given up on this aggressive F22 Bisimoto camshaft and will try my best to dial all else in, then we shall see what happens. I also did pull the plugs that were newly installed at the dyno session, they are fouled out again. I feel strongly that this is because I did confirm with the tuner, he never did partial throttle tuning as I made him stop at the 7500 RPM run. Therefore, that explains the under 3000 RPM stumbling. I am not sure on the AFR curve peaks and valleys, but I strongly feel that is due to me not degreeing the camshaft. I first plan to degree the camshaft, then reconfirm.Last edited by HondaFan81; 03-10-2009, 02:22 PM.
good stuff, my custom grind tops out right at 6900rpm and was not such a pain to idle. I have stock injectors with a fpr, tuned with crome. 161whp and 137 wtq is fun, but more never hurts.1990 accord Honda-Challenge, H22 powered
newer race video,older race videos
1991 accord parked, parts and back up shell
1993 accord acquired 6-11-16
