If you would like to add a DIY to the index, please post a link in here and I'll get it up as soon as possible. Otherwise I'll get it when I do random periodic checks for new threads.
Engine: Maintenance
***Opening your hood***
Basic Upkeep
Oil change Video
Do Your Own Oil Change
Alternative Oil Changing
Changing your spark plugs
Alternator & Power Steering Belt Replacement
Removing Alternator, PS pump, or just tightening belts
Battery Servicing
Adding washer fluid
High-Mileage Upkeep
Where is ______? (locations of sensors, relays, switches, etc)
How To Remove Timing Belt Video (1)
Timing Belt (2)
Timing Belt Video (3)
the official timming belt DIY for cb7's (4)
Replacing inner distributor seal
Distributor seals (ALL)
Replacing Cam Plug
Replacing Valve Cover Seal
F22 Spark Plug Tube Seal Replacement (1) - also here
Spark Plug Well grommet replacement (2)
How to get rid of the oil in the spark plug tube (3)
Spark Plug Tube Seals & Valve Cover Gasket Video
Injector seal replacement
Oil Pan Gasket Replacement
Oil Pan Gasket- Clearing up some Confusion
Oil Pan Removal and Replacement "Pix"
Replacing the rear motor mount
rear motor with out removing the intake manifold
Starting & Ignition Systems
Mitsuba starter rebuild
Replacing Starter
How To Replace Distributor
Igniter & Distributor Check & Replacement
Igniter/ICM Replacement
COIL INSTALL 92-93 ACCORD style
Alternator Brush replacement (1)
Replace your alternator's brushes (brush set) (2)
Fuel System
How to test Low Fuel Light bulb
Clean Fuel Injectors
Bench Cleaning Fuel Injectors (on the cheap)
Fuel Filter Replacement (1)
Change Fuel Filter (2)
How To Change Fuel Filter (3)
how to fix a broke fuel line
Swapping a Dented Tank for a good one
Fuel Pump Access
how to check your main relay and fuel system
MAIN RELAY REMOVAL AND REPAIR (pics)
Cooling System
Fill and Bleed coolant
Filling Coolant System
Replace an upper radiator hose
Radiator Install
Rebuild Radiator Cooling Fan Motor
Changing a thermostat VIDEO
How To Remove Honda Accord F22A1 Waterpump
Rough Running & Diagnostics
Diagnose a Check Engine Light and S/D4 errors
CEL Diagnostics & Basic Repair
Troubleshooting a CEL W/ Flowcharts
How To Diagnose Check Engine Light
ECU Resetting Instructions
Compression Test
check for fluid in your cylinders. Oil/coolant
Setting Base Idle Properly (F22ax, F22bx)
Setting Base Ignition Timing (F22ax, F22bx)
Cam Timing Instructions
Erratic Idle Fix (1)
Erratic idle how to fix it (2)
Diagnosing a Rough Idle (3)
Fast Idle Thermo Valve (FITV) Repair
Adjusting FIV for erratic idling
cleaning the throttle body
cleaning your throttle body
Cleaning out IAC Valve
cleaning out the IAC
Troubleshooting your IACV
IAB Black Box Nipple Fix
Setting TPS (1)
Setting the TPS Sensor (2)
Throttle Position Sensor or TPS removal
How To Remove The TPS Bolts (or any other bolt)
slide hammer (for EGR port cleaning) (1)
EGR Port Cleaning (2)
EGR Valve Cleaning (3)
O2 Sensor Replacement
Seafoaming an engine through the intake
Adding Seafoam to the crankcase
Installing PCV valve
Accessories
Power Steering Pump Rebuild
Recharge A/C
Changing your condenser
Taken out the Evaporator
Internal Issues
how to do a basic tear down of a f/h motor
How to check for bent valves w/ HEAD OFF
Cylinder Head Rebuild
Let's assemble a head!
Valve removal
Valve Spring Removal
Valve Adjustment VIDEO! (1)
Valve Adjustment (2)
Crank pulley tool
Broken Crank Pulley Bolt Extraction
Engine: Modification
Fuel System
static fuel pressure gauge
adjustable fuel pressure reg. and gauge install
Making your own fuel pressure guage
Walbro Fuel Pump Install
DSM Injector Install
Injector Removal/450cc Install
Fuel Charcoal Canister Delete
Cooling & Lubrication
Coolant Overflow Tank (1)
ROCKSTAR energy radiator overflow tank (2)
TB Coolant Bypass
Harbor freight Oil Catch can
oil "catch" can (easy, cheap)
Oil Catch Can (a different method)
GReddy Oil Catch Tank
Modify main bearing oiling holes
Oil Filter Magnets! (1)
Magnetic Oil Plug + Oil Filter (2)
Electrical
P12 Install (1)
Safely securing a P12 ECU (2)
OBD I scan tool
CEL & ABS Custom Wiring
No cutting wire tuck (1)
Wire tuck (2)
Wire-Tuck (3)
Wire Tuck + Fuse Box Relocation
Install OEM Block Heater
Upgraded charging system
"BIG 3" upgrade + upgraded positive wires
220 alt
Internal to External Coil Dizzy Conversion (1)
Internal to External Coil Dizzy (2)
Internal to external coil (3)
Convert internal coil distributor cap to external coil (4)
Installing An Msd 6al W/ A Blaster Coil 2 / 3
Spark Plug Indexing made easy!
Intake & Exhaust
Adjustable IAB Control...w/o ECU!
Cold Air Intake Install
short ram intake bracket made easy
How to Make a Fibreglass or Carbon Fibre Car Airbox
cone filter intake using the factory rubber intake tubing
using stock intake tube with 3" cone for RAM AIR
Custom short ram intake & heat sheild
Turning AEM Short Ram into Ghetto Cold Air Intake
Increasing air flow to your cold air intake
bumper light intake scoop
Installing Aftermarket Throttle Body
F22a6 intake manifold swap; coolant refresh; seafoam job; oil/filter change #2
Gutting stock intake
H-series Plenum on F22A6 runners
H23 Intake Manifold Swap (56K die!!!)
plenum spacer
Port & Polish
port and polishing
FITV Delete, Home Depot style
EGR removable plugs
Header wrap!
Header/ Exhaust Install
Aftermarket Exhaust Install
Installing Collector Studs Into Cheap Stainless Headers
Mounts
front motor mount (Torque Mount)
Solid Polyurethane Engine Mounts- Performance & Repair
Polyurethane Engine Mount Install
Urethane Motor Mount installation
Solid Urethane Motor Mounts
Ballistic Rubber Torque Mount Insert
Dress-up
Engine Detailing/Cleaning
Polishing small parts with a dremel
Painting The Valve Cover
Paint your Valve cover w/pictures
Polishing The Valve Cover
Heat Shield Black Out
Beauty Washers for your Engine bay
Sleeper engine bay
Accessories
ac removal f22a1 (with pics) (1)
The A/C delete DIY (2)
Do it Nice or Do it Twice A/C Retrofit !!
Power-steering Removal - Line Looping
1986-1990 Acura legend power steering fluid dip stick
Engine: Forced Induction
Properly Choosing a Turbo Size
How To Rebuild a Turbo
Front Motor Mount Replacement for Turbo CBs
External Dump O2 Housing
Engine: Swaps
Common Swaps Info can be found in here. PLEASE READ HERE FIRST
F- and H-series Swap FAQ
Official CB7Tuner Frankenstein/Hybrid Swap List
Replace Timing Belt, Timing Balancer Belt and Water Pump on a F22B1
Vtec Head Swap HOW TO
F22B DOHC Head Swap onto F22AX Block
solution for f22b dohc power steering belt fiting problems
Properly modified H22a head for F22 block
Vtec Solenoid Maintenance
DOHC engine valve adjustment
How To Degree DOHC Camshafts
H22 Valve Spring Removal (New Tool Review)
H23 Manual Tensioner Conversion on H22
OBD2 to OBD1 wiring for Map Sensor
OBD2 to OBD1 Distributor Harness
Blacktrax IMS
H22 Euro R Intake Manifold
H22A ATR/Euro R IM While Retaining All Stock Functionality
Transmission: Maintenance
Automatic Transmission Codes
Replace the Vehicle Speed Sensor (VSS)
Back-up/reverse sensor replacement
Fixing/Replacing Neutral Safety Switch
90-93 TCU Fix / Preventative Maintenance
Replacing A/T shifter cable
Transmission Removal How To Video
automatic tranny swap
How to take the tranny housing apart
manual transmission drain/refill (1)
Manual Transmission Fluid Change (2)
10 Minute Transmission Flush
Replacing Clutch Release/Slave Cylinder
Replacing Slave Cylinder
Clutch Slave Cylinder Rebuild
One man clutch bleed
Throwout bearing fork install
Clutch Replacement
Clutch Replacement *56k? the 90's called, they want their internet back*
How to remove and install a clutch for 1990-95 Accords
Transmission: Modification
00 civic si clutch master cylinder swap
Installing an S2000 CMC
Short Throw Shifter (1)
short throw shifter (2)
Fushigi RES Short Shifter Install (3)
Transmission: Swaps
CB P/S Vehicle Speed Sensor (VSS) Retrofitted to H22 U2Q7 Transmission
Drilling/tapping prelude transmission to fit an accord - (also here)
auto to 5spd conversion (1)
5 Speed Transmission Conversion (2)
Engine: Maintenance
Basic Upkeep
Oil change Video
Battery Servicing
Adding washer fluid
High-Mileage Upkeep
Timing Belt (2)
Replacing Cam Plug
Replacing Starter
Fuel System
Fuel Pump Access
Cooling System
Radiator Install
Compression Test
Setting TPS (1)
Accessories
Recharge A/C
Internal Issues
Valve removal
Crank pulley tool
Fuel System
TB Coolant Bypass
Electrical
P12 Install (1)
OBD I scan tool
Wire tuck (2)
Wire-Tuck (3)
220 alt
Intake & Exhaust
plenum spacer
Port & Polish
port and polishing
EGR removable plugs
Header wrap!
Mounts
Dress-up
Sleeper engine bay
Accessories
Engine: Swaps
Blacktrax IMS
Clutch Replacement
Transmission: Swaps
